bassmonster15 Posted August 23, 2010 Report Posted August 23, 2010 2x Blaupunkt VPA1500PRO Amp linked will create how much power. Anyone has tried this. Max. Power (Watt): 3000 Max. Power 1 Channel @4 Ohm (Watt): 1100 Max. Power 1 Channel @2 Ohm (Watt): 1900 RMS Power 1 Channel @4 Ohm (Watt): 550 RMS Power 1 Channel @2 Ohm (Watt): 950 RMS Power 1 Channel @1 Ohm (Watt): 1500 Signal-/noise ratio at nominal power (dB): > 100 Signal-/noise ratio at 1 Watt (dB): > 75 Stability normal mode (Ohm): 1 BLAUPUNKT VPW 380 BLAUPUNKT VPA 1500PRO AMP
