2000 Lincoln build RE MT/SX 15s in a 6th order
how are you going to fire the RE's? in a box like before or the regular facing the deck lid? i just finished a install where a fi BL 15 fires through the rear deck in a my 97 crown vic
1997 crown vic police interceptor
headunit: avic x710bt
sub amp: powerbass xta 1500d
sub: fi 15" bl fully loaded
enclosure: 3.5 cubes @ 33hz firing through rear deck
mids/highs: crappy pioneer paper cone 6x9's and stock rears for now
mid/high amp:h/u power FTL
wiring: knuconceptz 1/0 memphis interterconnects
I'm trying something like a blowthru under the rear deck box in trunk.
well unless you plan on doing some serious cutting/welding your box can't be taller than 11" over the gas tank hump unless the towncar's trunk is different than mine. i had to cut out the outer skin of the top of the trunk to get my 11" box in and it still barely fit through
ok let me try again the space between the rear deck and the gas tank will be framed in and the box built in the trunk subs firing thru the frame into the car.
