Carroot1 Posted September 15, 2010 Report Posted September 15, 2010 So I recently changed my mind. Im thinking of getting 2 12 inch Kicker CVXS dual to ohm which are rated at 750 a piece which will be hooked up to a HFi2000D States it does 2000 Watts RMS at 1 ohm, is that true? If not any other amps in that price range my budge it about 800 dollars. How would I wire it down to 1 ohm. Also The amp does 1300 watts rms at 2 ohms which is only 200 less than what the subs can safely do. Is this amp a good choice? Thanks in advance.
