SPLGEO Posted October 9, 2006 Author Report Posted October 9, 2006 i'm replacing a few things... kintek 1800 under teh hood NEw H/o ATL..... the ISAC SQL chart says a min. battery amperage of 1600 for 3000-3500 watt rms setups.. so I think aroudn 1900 should handel it Quote 1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
Guest 90accordman Posted October 9, 2006 Report Posted October 9, 2006 i'm replacing a few things... kintek 1800 under teh hood NEw H/o ATL..... the ISAC SQL chart says a min. battery amperage of 1600 for 3000-3500 watt rms setups.. so I think aroudn 1900 should handel it i dunno about that, the kinetik Calculator wants me to run 2 1800s and my g34 yellow top up front. Thats for 3k watts Quote
SPLGEO Posted October 9, 2006 Author Report Posted October 9, 2006 dang that is alot Total RMS Minimun Total RMS Minimum Wattage of Battery Wattage of Battery System Current System Current 0 - 50 675 1100 - 1200 1250 50 - 100 700 1200 - 1300 1300 100 - 150 725 1300 - 1400 1350 150 - 200 750 1400 - 1500 1400 200 - 250 775 1500 - 2000 1450 250 - 300 800 2000 - 2500 1500 300 - 350 825 2500 - 3000 1550 350 - 400 850 3000 - 3500 1600 400 - 450 875 3500 - 4000 1650 450 - 500 900 4000 - 4500 1700 500 - 600 950 4500 - 5000 1750 600 - 700 1000 5000 - 6000 1850 700 - 800 1050 6000 - 7000 1850 800 - 900 1100 7000 - 8000 1900 900 - 1000 1150 8000 - 9000 1950 1000 - 1100 1200 9000 - 10000 2000 thats the chart i used.... Quote 1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
SPLGEO Posted October 9, 2006 Author Report Posted October 9, 2006 humm iono that does seem like alot of over kill. 4,800 amps of current.. I wounder if it takes into account any other eletercal upgrades id be comfortable using it daily like that, theres alot of other people doing it. I just fried a Colossus on 1.4ohm per channel. Just be sure to have the power to back up the amp How did you frie teh colossus i thought it was 1 ohm stabe per channel Quote 1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
SPLGEO Posted October 9, 2006 Author Report Posted October 9, 2006 aslo in teh vid. I posted before showing off the BEst subs in teh world :^ it looks liek they ar eyouing the Colossus but at the end they say the power was 50 amps at 100 volt.. which means 5000 watts how did they get that much power out of that amp with out cooking it Quote 1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
