dugee81 Posted September 21, 2010 Report Posted September 21, 2010 So long story short, stock serpentine belt is a little too loose, and the next size down (1/2in shorter) is tight to the point where the idle pulley cannot shift in place. I get slight belt slip at start up, for about 5-6 seconds and then it catches and stops. What can I do about this? Is there a belt I can order that is inbetween the 2 sizes I have now? Or can I purchase a bigger idle pulley? I figure because I can't actually use the adjuster on the idle pulley, the belt is not covering enough of the alt pulley and therefor not catching at low RPM. Any help is appreciated, thanks! 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
