dugee81 Posted October 7, 2010 Report Share Posted October 7, 2010 http://www.caraudiodeals.com/audiopipe-ap30001d-p-1453.html try that He said that amp is too large 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
dugee81 Posted October 7, 2010 Report Share Posted October 7, 2010 So with that amplifier what do you think i could get with voltage around 12.5-13.5 running at 2.67 ohms? Roughly 1000 is my guess. I just wouldn't even waste the time or money on it. I think those amps have like 200 amps of fusing on them.. Which says on 12 volts at the lowest supported ohm load it would produce roughly 2k. Double the impedance, halve the output. 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
teamace24 Posted October 7, 2010 Author Report Share Posted October 7, 2010 That amp was always in my list of wants but i really dont have the room or want to make room for the 30 inches wide it is. I was also looking at the ap aqx2500.1 but its a 1 ohm stable and i feel im going to waste its power. What about the pa a3000db or something like that its called, do you still know that bamf could do at 2.67 and 12.5 volts. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31 Link to comment Share on other sites More sharing options...
teamace24 Posted October 7, 2010 Author Report Share Posted October 7, 2010 What about that pa a3000db on 2.67 ohms. I dont even know how much they go for though. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31 Link to comment Share on other sites More sharing options...
dugee81 Posted October 7, 2010 Report Share Posted October 7, 2010 I think the pa a3000db was discontinued, so you'd have to find it used. Correct me if I'm wrong and you found it. I have read that it is a good amp, will produce a solid 2300wrms, but I think that's at 1 ohm as well 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
teamace24 Posted October 7, 2010 Author Report Share Posted October 7, 2010 I think the pa a3000db was discontinued, so you'd have to find it used. Correct me if I'm wrong and you found it. I have read that it is a good amp, will produce a solid 2300wrms, but I think that's at 1 ohm as well What do you think it could honestly put out at my voltage and at 2.67? 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31 Link to comment Share on other sites More sharing options...
teamace24 Posted October 7, 2010 Author Report Share Posted October 7, 2010 Didnt that amp produce the 2300 at 2 ohms? 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31 Link to comment Share on other sites More sharing options...
teamace24 Posted October 7, 2010 Author Report Share Posted October 7, 2010 Says 1800 at 2 ohms so will i be atleast around the 1500 mark? 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31 Link to comment Share on other sites More sharing options...
dugee81 Posted October 7, 2010 Report Share Posted October 7, 2010 Says 1800 at 2 ohms so will i be atleast around the 1500 mark? yeah. i dont know what the pa a3000db was rated at, i assume 14.4, so i would expect 1200,1300-1500 @ 2.67 your sig says you have an AP 1500D, do you know if it is possible to strap 2 of them together? maybe just do that, and stack them on top of eachother. save space and you get what youre looking for (pretty much)! 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
teamace24 Posted October 7, 2010 Author Report Share Posted October 7, 2010 The thing is my 3 subs will only handle 600-700 rms each so a 3000 watt amp even if it is running around 2500 rms will still leave me in fear of popping them and i dont like always thinking they might blow and easing on the volume, i like to play full tilt at all times. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31 Link to comment Share on other sites More sharing options...
