Guest grim83 Posted October 23, 2010 Report Posted October 23, 2010 ok so i bought some 6.5in speakers to go into a 6x8 mount...any ideas of an easy way to make them fit, i was thinking some thin mdf or cheap o wood cut to fit the whole and then mounting the 6.5s in that
AA98hoe Posted October 23, 2010 Report Posted October 23, 2010 yep thats the way 1/4 mdf make a template or abs TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
