small build in a mercededs 190e
This is an install that I did for a customer in his 1993 190E. He wanted a double din in place of the single din, one 12, and all the speakers replaced. I did some searching around for him and found him some good deals on products that would get the job done. Although they aren't the best products I am overall satisfied with how it turned out and the sound it really nice and crisp.
(This is my first install for a customer and I learned a lot from it, I am working my way up to hopefully be able to do this for a living)
The start:
Now that I have the new clarions installed I started working on the dash to get the double din to fit. I superglued these plastic spacers in to raise the hu high enough to look right
I bent these metal tabs and bolted them to the top plastic piece and the top of the hu bracket to keep it from sagging down in the future. I had to grind down each bolt for clearance
And there u have it, a custom mounted double din
I painted the face of the box to match the color of the car and the port black, wired everything up and screwed it all together and then tested it out
Overall I am happy with the way it turned out and I learned a lot from this experience. I have never tried making trim panels before so this was a first and took longer than it should. Also there were a few things that I could have done to make it look a little better and some things that could have used some more attention. But like I said this is the first time I have worked on a customers car and I charged him a low rate so I can try to get my name out there and also gain experience which I feel like I did. Any criticism is appreciated. Thanks for looking
  • Who's Online   1 Member, 0 Anonymous, 1015 Guests (See full list)
