looks loud man. one thing i do recommend though. i see you are dropping to the low 12's on that capacitor you have. take out that capacitor and you should notice the voltage increase a little bit. also, have you done the big 3? that will also help boost your voltage and cut down voltage drop even more.
what do yuu mean about the big three.
http://www.stevemeadedesigns.com/board/topic/13280-how-to-do-the-big-3-tutorial/
you basically add on 0 gauge wires from alternator + to battery + and battery - to strut tower (or frame) and battery - to a good solid ground on the engine. i did it and i gained almost a half volt on my stock alt.
Sound like a thing i could do, what if i just take the capacitorr, would i get moree than 12?
i dont know if you will get more than 12 volts. all depends. the reason i say take out the capacitor is because if your voltage is dropping, the capacitor isnt helping at all. it just adds more of a strain on your alternator which is already trying its hardest. the big 3 will help tremendously also. its a pretty cheap addon, like $30 if that.
