Need help with port design, very confused!
DJ JDub
Should be picking up the wood sometime either this week but for sure next week. But for bracing the box, could i just double up the wood on top? or put some beams inside the box as well?
Has not so understood a question... :nea:
Now I shall draw that has understood
ВАЗ 2107........145,2 dB.........НОЭМА
Im saying bracing the whole box not the inside of the port, so that it doesnt flex.
I have understood you!!! :yahoo:
Building a box As is...Durabilities should suffice! :good:
your diagram shows 38" as a inner dimension unless your blazer is wider than mine 38 is as wide as you can go also i would do sub up port back i done 4-12"s in mine got a 153.4db out of it sealed on the dash.
sealed up on the termlab mic on dash 4-sa12"s 2-3500d's 153.4db now testing a american bass 1100.1 no numbers yet 300amp iraggi alt and kinetik batts.
you can fit between the wheel well 40"
and i cannot put port back because that is where my amps are located
so i cannot find 1" MDF anywhere local, so would i still be safe to make it out of 3/4"?
ok! you are buy 3/4" and build double up the wood on top. But the port should be 3 "!!!
ok thanks, and what kind of screws work for everyone, the last time i used mdf the screws messed it up so any suggestions? (yes i did predrill before putting the screws in)
I drilled before putting the screws in, too!
(this is my home 10" sub, MDF 1,6"!!! :yahoo: )
  • Who's Online   0 Members, 0 Anonymous, 751 Guests (See full list)
