Then set it at 38.73 for 1500. That's if you have 2 subs, the 24.49 was for only 600 watts so if you have 2 subs then you would set it at 1200w setting which is 34.64 for the rms on the subs
Wait, So Yes, I have 2 subs, 600 rms. On a 1500w amp. Giving the subs 750 each. So do I go by 600 or 750?
Go by the 750x2 so go with the 1500 one if you go with the 600x2 you will set it for only 1200w
That tell me what I need to know. Thanks a bunch guys. Would you recommend setting it to the exact voltage it says, or a little lower just to be safe?
Regardless of what voltage you set it to you might still be clipping and the only way to find that out is to scope that bad boy.. I had my voltage set correct on my last setup but when I got my O-scope I found out I was clipping hard..
Rebuild Log with the SMD
CURRENT..
Honda Accord Coupe
Porsche Cayenne S
Lexus CT200
Lexus ES300 (sold)
99 Lexus RX 300 (sold)
ADDING
Honda - Hertz setup, more to come
Porsche - Fi BL, XS Power, more to come
coming soon..
peep the old rebuild log of the Lexus RX
Hey guys, i also suggested him to set everything with a DMM but he´s still looking for a O-Scope in the Colorado Area, i´m bumping this because he has some problems posting right now, anyways, he´s asking if someone on that area has one that can be borrowed or maybe charge a few bucks for it´s use, should be quick really, help him out! :drinks:
Man if you ever come to So Cal I'd let you use mine..
CURRENT..
Honda Accord Coupe
Porsche Cayenne S
Lexus CT200
Lexus ES300 (sold)
ADDING
coming soon..
  • Who's Online   1 Member, 0 Anonymous, 1509 Guests (See full list)
