How to transfer iPod music to computer? How to copy iPod to computer? The following is comprehensive tutorial about iJoysoft iPod Transfer Ultimate, which guide you to transfer video, audio, photo files between iPod and computer, transfer iPod music to computer, transfer and iPod Transfer files to iTunes library, copy DVD movies to iPod, transfer incompatible media files like AVI, MPEG, WMV, MKV, etc from iPod Transfer, and share files among various devices with iJoysoft iPod Transfer Ultimate, the perfect iPod backup and iPod Converter software.
In reality, this informative guide is definitely divided into these parts:
Part 1: Import supported media files to iPod
Part 2: How to copy iPod to computer, backup all iPod files to computer
Part 3: How to transfer and copy iPod files to iTunes library
Part 4: How to copy DVD movies to iPod/iTunes
Part 5: How to transfer incompatible media files to iPod/iTunes
Part 6: How to share files among multiple iPods and iPhone
First, please download, install and run this iPod backup software iJoysoft iPod Transfer Ultimate. Then connect your iPod or iPhone to computer. Next, your iPhone/iPod will be automatically recognized by this iPod backup software, and its device information will be displayed on the interface.
Tip: This iPod backup software can connect as much as 26 iPods and one iPhone/iPod touch at the same time.
Step 1: Open the library/playlist that you would like to import.
Step 2: Click the "Add File(s) to Device" drop-down button on the bottom, select the "Add File(s) to List" option, and choose the files you need in the dialog that opens, after that import them to your iPod, or select the "Add Folder to List" option to find the folder you need, and import every one of the files in the folder to the list.
Tips:
1. You can even right click the library/playlist, and choose "Add File(s) to List" or "Add Folder to List" option to import the files you need to add.
2. In case you want to connect more than one device and wish to transfer the files to them simultaneously, this software can easily realize your needs. You could first click "Video/Audio" node and load your needed files to the list, after that check the files you would like to import and then click the "Export Checked Files to Device" button, next the "Select Copy Destination" dialog will appear to request you to select the target devices you need to copy to. Confirm the devices you choose, and click on "OK" to begin the process importing the files to your checked devices simultaneously.
Part 2: Copy iPod to computer, backup all iPod files to computer
When you want to copy iPod to computer, transfer iPod music to computer, or copy any other files like movies, songs, pictures from iPod to computer, you could follow the guide below. This iPod backup software is easily handled to copy iPod to computer.
Step 1: Open a library/playlist, and confirm the files you would like to export.
Step 2: Click "Export Checked Files to Local Folder" drop-down button, after that select "Export to Local" option, next choose the folder for saving the checked files in the dialog that opens to begin exporting.
Tip:
You can even right click the checked files, and choose "Export to Local" option to begin to export the files to the folder you desire.
Part 3: Transfer and copy iPod files to iTunes library
Step 1: Open a library/playlist, and confirm the files you need to export.
Step 2: Click "Export Checked Files to iTunes" button, after that iTunes opens and the program begins to export the files to iTunes.
Tip:
Additionally you can right click the checked files, and choose "Export to iTunes" option to begin to explort the files to the folder you choose.
Part 4: Copy DVD movies to iPod/iTunes directly
Step 1: Insert a DVD movie disc you would like to copy.
Step 2: Select the DVD/CD node from the left tree, and click on "Open DVD" drop-down button on the bottom, after that pick the inserted DVD discfrom the drop-down lost, or select a DVD folder, ISO file or IFO file on your local disk, then load them into the list.
Tip:
It's also possible to right click the DVD/CD node from the left tree, click "Open DVD" and select the inserted DVD disc, or click "Open DVD > Other Folder" to pick a DVD folder, or click "Open ISO Files…" or "Open IFO Files…" to load the ISO or IFO files you need to import.
Step 3: Confirm the files you wish to import in the list, and click "Export Checked Files to Device" or "Export Checked Files to iTunes" button to copy them to your iPod/iPhone or iTunes library.
Tips:1. If you have connected multiple devices, then after you click the "Export Checked Files to Device" button, the "Select Copy Destination" dialog will pop up, you can choose the target devices you want to copy files to. Check your chosen devices, and click "OK" to start copying these files to your checked devices simultaneously.
2. In case you didn't connect any device, once you click the "Export Checked Files to Device" button, the software will remind you that no device is connected. Click "Yes" to keep ripping DVD movie and save the converted media files in the Video/Audio node for later operation, and click "No" to cancel importing DVD movie.
Part 5: Transfer incompatible media files to iPod/iTunes
Step 1: Click the Video/Audio node in the left tree.
Step 2: Click the "Add File(s) to Device" drop-down button on the bottom, choose the "Add File(s) to List…" option, and choose the files you need, add them to the list. Or choose the "Add Folder to List…" option to locate the folder you need and import all of the files from the folder to the list.
Tip: You may also right click the Video/Audio node, and choose "Add File(s) to List…" or "Add Folder to List…" option to add the files you need.
Step 3: Check the files you need in the list, and click "Export Checked Files to Device" or "Export Checked Files to iTunes" button to copy the files into your iPod/iPhone or iTunes library.
Tips:
1. If you have connected multiple devices, then first click "Video/Audio" node and load the files you want to the list, then check the files you want to import and click the "Export Checked Files to Device" button, then the "Select Copy Destination" dialog will pop up to ask you to choose the target devices you want to copy to. Check the devices you want, and click "OK" to start importing these files to your checked devices simultaneously.
2. If you didn’t connect any device, then the application will prompt you that no device is connected. Click "Yes" to continue converting the files and save the converted media files in the Video/Audio node for later operation, and click "No" to cancel adding the files.
Part 6: Share files among several iPods and iPhone
Step 1: In the left tree list, open a library/playlist in one of the connected devices, and then check the files you want to copy.
Step 2: Click "Export Checked Files to Local Folder" drop-down button, then choose "Export to Other Device(s)…" option to start exporting the files. Or you can right click the checked files and choose "Export to Other Device(s)…" option to start transferring the files to other devices.
In conclusion, this multipurpose software iJoysoft iPod Transfer Ultimate is not only an iPod backup software, which can transfer iPod music to computer, copy iPod to computer, transfer files from iPod to PC, iPod Transfer, iPod Transfer to iTunes, but also professional iPod converter tool to convert and copy DVD movies, other videos to iPod very easily and expediently
This topic is now closed to further replies.
