MACnonsence6 Posted December 21, 2010 Report Share Posted December 21, 2010 ok im planning to order another pair of hifonics 12s for my room. now for the box i want my other towers to be able to sit on top of them.so my question is can i build a box to 2.5 cubes with these dementions h-doesnt matter just as long as the sub is facing farward. w-31" and 20" deep idk the displacement of my sub yet im not to sure how to figure that out. but the port for the box would be 3" x 4.6 deep these are the specs from the site for 34hz my main question is well one how do i figure out the displacement of my sub so i can add that to the totall gross of the box. second using w,e material thickness could a box be built to those specs with those dementions I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
SlamDUNKmyJUNK Posted December 21, 2010 Report Share Posted December 21, 2010 The specs on Hifonics's website should tell you the displacement, and I don't understand what you mean with the thickness. You can use what ever thickness you want, 3/4 of an inch would be fine. Link to comment Share on other sites More sharing options...
MACnonsence6 Posted December 21, 2010 Author Report Share Posted December 21, 2010 well becouse of the dementions of the box i need compared to the internal cubes i need. thicker wood could give me the dementions i need while keeping the interal 2.5 thats if the dementions i need are to large to make 2.5 if that is the case that the box would be way to big to give an internal of 2.5 then i could also double the sheets of wood to make the outside what i need as well making the inside the size i need if that makes sence? I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
MACnonsence6 Posted December 21, 2010 Author Report Share Posted December 21, 2010 vas-107.4 liter sorry if thats wrong if it is let me know I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
