try different speakers. and mp3 player again. if it doesnt work then, then the amps are toast...somehow.
there was a problem with JL products doing this. i ended up purchasing one off of ebay in a scam type of situation. i think its the output section of the amplifier that is shot. youre probably gonna have to get them fixed, if its worth the money...
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
i garentee you its a ground honestly
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
pop your speakers to see if they are good use a cordless battery
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   1 Member, 0 Anonymous, 529 Guests (See full list)
