drlovebangin318s Posted August 30, 2007 Report Posted August 30, 2007 i used a volt meter on the positive and negititve from the amp and i was geting 13 somthin volts.. i never saw no volt drops while my car was idling with no ac or anything else on.. but when my lights are on they dim .. am i supposed to meter from another location???
Guest MegaloManiac Posted August 30, 2007 Report Posted August 30, 2007 you should be fine around 13.8
drlovebangin318s Posted August 30, 2007 Author Report Posted August 30, 2007 you should be fine around 13.8 well it was like 13.3 or 4.. some in the midd to low 13's.. i just did a big three with 4 gauge and i now i get 14volts at idle with stock atl. and battery...
Guest MegaloManiac Posted August 30, 2007 Report Posted August 30, 2007 still isnt soo bad, the second you dip in to the 12s then you have problem that you should be really concerned about
gotFI? Posted September 6, 2007 Report Posted September 6, 2007 im running a stock alt and battery up front and a second stock battery to the rear. when my fi bl 18" hits, the lowest is @ 13.2 volts. not bad. amp is a rf t10001bd.
drlovebangin318s Posted September 12, 2007 Author Report Posted September 12, 2007 im running a stock alt and battery up front and a second stock battery to the rear. when my fi bl 18" hits, the lowest is @ 13.2 volts. not bad. amp is a rf t10001bd. how you like bl?? im thinkin about gettin 2 18 bl's... you think they can handle 1600 rms.. the site says 1000 but i dont know..
doughboi916 Posted September 13, 2007 Report Posted September 13, 2007 when i turn my gain up my DMM reads a higher voltage? is this supposed to happen? it was around 13.4-13.6v idle and i turned the gain on the amp up and it read 13.8-14v???
