AA98hoe Posted January 14, 2011 Report Posted January 14, 2011 if you peak at 45 to 47 then go with those cause thats going to be the loudest. i peak at 38 so if i play thugmotivation which peaks at 40 my voltage drops and i get the subs smelly. if i play juicebox which peaks at 38hz (right on the money) voltage stays fine and i can rail on it with no smell. i did a 130.9 at park and pound with that song and did a 151.7 off the glass with driver door open for 30 secs. TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
LoudNLow931 Posted January 14, 2011 Author Report Posted January 14, 2011 Nice. My peak may have changed because I'm switching to 18s and a different box. Ill have to run a sweep again. 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
LoudNLow931 Posted February 17, 2011 Author Report Posted February 17, 2011 ok so my peak changed ALOT, Needs songs in the 35-36hz area. xD 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
