Question about Pro Audio Power distribution
Anyone have any idea where I can find out about how large PA systems power multiple amplifiers? I'm going to be getting two XTi 4000's at 4 ohms (3200 watts apiece) along with a chosen mid/high amp (more than likely my current EP2500) and varying processing gear.
Also, for the big guy, how you liking your XTi's, and what are you running them off of power wise? Single 20 amp circuit, multiple, etc. Help a follower/silver member out? :D Thanks to anyone that helps.
POTATO!
You use the xlr output on the amp and run it to the input on the next amp. The XTI's have a computer programed crossover and EQ. All you have to do is set them accordingly.
Edited by Kasey
"Audio is not a hobby it's a lifestyle"
_____________________________Refs_1_Refs_2_____________________________
I know that. I'm talking about the power itself. I've seen those giant twist-lock connectors used on bigger systems.
POTATO!
do you have a pic of said connector ? Are you referring to the speakon connector?
No. If you look on most big setups, they have speakon-like twist-lock connectors for power, connection, etc. They're like 3-6 inches across.
POTATO!
those are for like 220v if you run it of a 40 mp breaker u should be good thats the same as a washing machine and if you blow that slightly jump up til u dont blow unless you can meter it and do calculations but i dont know the math... so sorry
1994 honda accord 2.2L VTEC
sub is re se motor with fi cone in a pre fab box
stock door speakers on an alpine v12 4 channel
sub on a 1000 watt alpine monoblock
need a dash kit and harness to put my alpine deck in
also need tons of sound deadner
need to install my apline type r compontents up front
need to buy type r 6x9's for the rear
  • Who's Online   1 Member, 0 Anonymous, 1433 Guests (See full list)
