New Box Time,..Is this Okay?
ive built a few ported boxes in the past and never had any issue with how they sounded.
But want to know if there anything i can do to make it sound better, its for Street Bass not SPL.
Kit list:
Amp - Orion D5000 (2.5kw rms)
Sub's - 2 x 15" Fi Bl's
Car - Vw Golf Mk2 3dr.
Boot space - 37" Width , 25" depth , 22" hight
last box was 6cuft @ 35hz
heres my Design for the new box 8.4cuft @ 34hz with 12.55 SPA Per Cuft
let me know what you guys think, will be 25mm top & Bottom , 18mm on sides.
Kit List:
Car: 1990 VW Golf MK2
Engine: 2.8 Vr6 200bhp
Headunit: Alpine CDE-9880R
Speakers: 4x 6.5" Vibe Black Air Comps
Subs: 2x 15" Fi Bl's D2
Amps: Orion D5000 (2.5kw) & Alpine MRV-T502 (300wrms)
Processors: Rockford Fostgate EPX 2 , AudioControl Epicenter
Power Supply: 250amp alt , 0awg wireing , Yuasa SWL 2500FR Batterys
everything looks good to me. if you want to be a tad louder, aero ports are supposed to help out alot
hi mate , thanks for the reply .. i know about Aero ports , ive not heard a big install that used aero ports then a slot/square port.
The current port in this design is 3" wide and i will try and round off the edges as much i can to keep port noise down and aid air flow.
but i dont think there should be any issuse as ive used 12.55 SPA per cuft , rather then 8 - 10 like other boxes ive done.
also i can see if loading off the tail gate glass helps if not swing it around and load of the roof, with out too much effort.
Kit List:
what is SPA? we usually use square feet around here. generally its 12 - 16 sqin (square inches) of port per cubic foot. 9-11 or something like that for aero ports
SPA= Square port area.. we use inches over this side. and 8-10 for slots and 5-8 for Aeros (its what ive read and been told to use as minnium)
Kit List:
