Nparadiso2 Posted January 3, 2013 Report Posted January 3, 2013 I just ordered 2 12" SSA Dcon's and an audiopipe apsm 1300 amp and i need to come up with a design for the box i will be building. It is going into a 2005 saturn Ion. It cant be taller than 16" or wider than 33" and i have plenty of depth i just havent measured it out. I was wondering If you guys had any suggestions/recommendations for a design.
Joe X Posted January 3, 2013 Report Posted January 3, 2013 So here is a suggestion, assumes your subs are DVC4 ohm to take advantage of the 1 ohm final load that your amp supports port/subs frontwards or backwards: Enclosure Specifications: Fb = 32 Hz Vb = 4.1 ft^3 External Height = 16 in External Width = 33 in External Depth = 22.5 in Port Width = 3 3/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2x Front = 14 5/8 x 14 1/2 Back = 33 x 14 1/2 Left & Right Sides: 21 x 14 1/2 Top & Bottom = 33 x 22 1/2 Shared Port Internal Assembly Parts: 2 x Front to Back = 19 1/8 x 14 1/2 2 x Extension = 3 1/16 x 14 1/2 Assembly guide (generic dimensions): Important notes: - The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know. - All trunk boxes built outside the car need to fit in their way in not just have the right dimensions. - The port needs 3 3/4" of free airspace in front of it for proper operation. - Setting your amp's subsonic filter to 28Hz is suggested. So let me know if you want anything different.
