need help building sub enclosure
Probably help to post max dimensions, rms power to each sub, either desired tuning frequency or type of music listened to if you want ported.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
  • 4 weeks later...
Sundown recommends 4.25sq feet for just 1 of those 15's. I'd expect anywhere from 8-12 square feet is the size of the box you will need. Sundown actually gives you a box design recommendation on their website for 1 and 2 subs of each size. Once you get that, you can use this calculator to decide how long your port is or how to find out the deminsions of the box to get the square feet you require.
http://www.the12volt.com/caraudio/boxcalcs.asp
I would recommend something that doesn't use as much space. Personally, i'd get two SoundQubed HDC318's if I didn't care about space.
  • Who's Online   1 Member, 0 Anonymous, 1540 Guests (See full list)
