What are you trying to even do with it? Set a pass or what?
what track? what freq?
what amp? what drivers/speakers ?
Yes, ill say now, YOUR DOING IT WRONG.
Read the instructions you got with it.
I was trying to set two cresendo s1500 gain together. i am not trying to set the crossovers the same since the box is tuned dumb low. its an FI SP4 15in and I do believe it was track 10 that the instructions told me to use. I re read the instructions. plugged out the connectors on the CC before turning it on. turned it on then then calibrated it. as soon as i connect the negative to the ground then the positive, the signal is red.
This procedure requires the CC-1 to be placed in a
special mode reserved for SPL competitors and
audiophiles.
1. Switch the CC-1 off by holding the OFF button
for 1 second. (This must be done to initalize
the program mode) Now switch CC-1 power on
by pressing the ON button.
2. Disconnect the harness to make sure there is no
signal being applied to the CC-1 and that the
Signal LED is NOT illuminated.
3. Press and hold the READ button for 3-5
seconds or until the Set LEDs start flashing.
Release Set button. CC-1 is now in
competition mode!!
4. Next you need to connect the CC-1 to the
“Master” amplifier’s outputs. Use the included
harness to connect to amplifier’s outputs; Red to
speaker (+) and Black to battery ground.
12
5. Set the source unit’s volume to zero. Select the
track on the CD that corresponds to the desired
frequency you wish to match gains at. If you
don’t know which frequency to use try 40 Hz
(track 10 Disc A) if it is a subwoofer amplifier, or
1 kHz (track 8 Disc B) if it is a full range
amplifier. Play track on repeat.
6. Continue by turning up the source unit volume
until you see the Signal LED illuminate green. If
the LED turns red, this indicates the volume is
too high. Turn volume down until LED remains
green.
7. When Signal LED remains Green, press the
READ button. The Blue Calibrated LED should
illuminate.
8. Now without touching any adjustments on
anything, connect the CC-1 to the output of the
next amplifier that you wish to match it’s gain to
the first amplifier.
9. The LEDs will indicate if the gain is too high or
too low compared to the “Master” amplifier.
10. Adjust gain on the amplifier that the CC-1 is now
connected to until the Calibrated LED
illuminates. The amplifier’s gain is now matched
to the Master amplifier’s gain within +/- 0.05dB !!
I have issues with my CC. Whenever I turn the signal down on my amps, the red light never goes away. even when the radio is down and amps are down. am I doing something wrong?
What do you mean Whenever I turn the signal down on my amps,?
and signal meaning the cross over? or the gain adjustment. ???
Your master should be set clean. You then use the cc1 to MATCH the second one to the one you wanna mirror.
Please, when asking for tech help with the tools, you need to use your words proper for correct help.
You should ONLY be touch the gain on the slave amp..... The master should be set CLEAN , and then with the CC1 per instructions you will READ the master.
THen move to the slave, setting it to mirror the master using ITS gain only.
Edited by KyLar96
Thats the thing, I did those instructions before and even turned the radio signal down. I turned the volume gain down and didnt even get around to touching the crossovers.
Yes. I set that first, did my door speakers then moved my way to the amps.
dude.. when i say master, that means your amps...one of the 2 sub amps. that is what your trying to gain match right?
Edited by KyLar96
  • Who's Online   0 Members, 0 Anonymous, 660 Guests (See full list)
