Stetsom crossover
Get you a P99RS and solve all your problems in one simple head unit.
No other EQs, processors, or crossovers needed ...
Dam that is a nice head unit. But considering I already dumped a couple hundred bucks on a HU, I thought it would be cheaper to look for something else for xovers.
I understand ... I dropped a little better than a grand on my head unit.
I don't plan to change it any time soon.
Seems like a nice crossover network though. Never seen one in action.
We use to run Audio Control back in the day.
And's that's one of the many reasons why you are the best in sound quality! :)
So in a true 3-way active setup, should there be no frequency overlap b/w the drivers? Example: Midbass 100-250Hz, midrange 250hz-4kHz, tweeter 4kHz and up. Or it is good to have some overlap?
My concern with only a 12db/octave slope that the frequencies might not be cut "sharply" enough if there is no overlap. Would that be an issue?
I overlap everything in my system.
That is one of the beauties of time alignment.
We cut our drivers at the limitations of the specific driver. And start tuning from there.
Thanks for the tip!
When you crossover at these points, how noticeable of a difference can audibly be heard at a 12db/oct slope compared at an 18 or 24 one?
All depends on application and tuning. And the specific use for your system...
When you listen to a system for accuracy, placement, and dynamics ... Yes you can definitely tell minute differences in tuning.
The more you dive off into the audiophile world and leave the "loud and hair trick" world ... More suggestion that I have made in the past will make ALOT more scence
  • Who's Online   1 Member, 0 Anonymous, 1819 Guests (See full list)
