The Black Nasty - Wall build log "2011 Season, Rebuild 2012!!!!" - Quest for 160+ db!!!
I am going to document my wall build from start to finish on my quest to 160+ db. ON 12 Volt system!!!! Hope you enjoy. Any questions just ask.
Equipment list
Full wall enclosure ported for the peak of the truck and slide in music/daily port for demoing(37 hz fb).
4 AQ HDC3-v4 alum 15's
2 AQ 3500D.1's
4 kicker KS 6.5 components in front doors
1 Memphis 4.75
1 XS power D3100 underhood
5 BATCAP 4000s
1 XS Power VCM
2 Stinger 70 amp power supplies w/SCM modules
Kenwood excelon DDX812 Double Din
about 200 ft of stinger 0 gauge
Tejcurrent Quad alt setup - Yellow powder coat(600 amps at idle and 980+ at 2k rpm)- Clamped all four alts doing 242 amps each at 2k rpm!!!
First Kenwood hu and stinger volt meter in dash, shows voltage at amp(A must)
Amp for door speakers - Memphis 4 channel
Decided to run a pair of these each in the doors coaxial mount - Kicker KS Components
Start on fiberglass door inserts for the components
Quickstart alt (-220 amp in my testing) just for now
I did 4 runs of 0 gauge thru the firewall for now, 3 power and 1 ground, just for initial testing!!!
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Comparison my Kicker L7 15 to the AQ HDC3 15!!!!
Got wood??? And my buddy Mike letting the haters know what is coming....LOL
Getting used to the new lowered look I like it....LOL
Time to start!!!! Used just some speaker carpet on the back glass and then painted the side windows black
Make sure you charge these suckers before you install them, I had one that was pretty low 12.4 volts resting(It had to of been sitting for awhile)
This pic surprised me,,,This is my father-in-law giving the haters some more fuel....LOL
Deck done and back first sheet attached!!!!
Whole enclose is double walled 3/4 mdf
Grinding some screw tips off
Had to glass both top rear corner to make things work the way I needed them to, it is around 1 inch solid fiberglass!!!
It is IN!!!!!
Evo X build log
This shows the top rear corners very tight, but it fits!!! I always liked things tight....LOL
Shows the clearance on the side with the door shut - Nice home for some amps!!!!
Glass all the weak points that will be under loading.
About 3/8 inch thick glass - This part is a MAJOR PITA!!!!
Then AIR sand smooth and primer!!!
Test fit first front baffle
My buddy Mike again, he likes to express himself....LOL
Decided to mount my Memphis amp on the side and have some music while I work.
Evo X build log
Looks like it is gonna hurt!!!
SPL Port Done!!!
Test fit front baffle. I can see the light at the end of tunnel...LOL
Some guy I met one time said, "Oh man those blue lights are so sweet man, those are awesome"....LOL
Clearances look good with the door shut and amp mounted.
Some more angles
Nice big port!!!
Looks mean from the front!!!
Saw dust all over the truck!!!
Second baffle done!!!
Traced out trim(beauty panel), this was a MAJOR PITA!!!!
Test fit trim panel.
Decided to make it more of a PITA and flush mount the subs.
Test fit aq sub.
Evo X build log
Done!!!
Bottom two subs installed
All four installed!!!
AQ 3500D.1's....yum
Stinger 8 gauge for speaker wire.
Each voice coil wired to solid brass studs.
Amps mounted, had to trim the door panel some to allow everything to fit. But that can be fixed!!!
A little glass fixed that right up
Looks factory some what.
That looks better. 1/4 inch of clearance when shut, perfect.
Amps wired up!!!
Evo X build log
Alright, now some numbers, first burp, no shit with zero tuning, just hooked up and burped it.
My buddy James, his son(Chase) fits in the port no problem, hell I fit in the port no problem....LOL
Decided I would break them in on a smaller port and it would be better for pressuring anyway. Tuned to 37 hz.
Done completely and I like it ALOT!!!!
Alright some more numbers, amps strapped at .5 ohm, clamped power at 10.5 volts 9200 watts and did this number legal sealed on the dash!!!
Then outlaw style in the kick, did this on same power. That made the whole build worth it!!!
Then did this at a show a few weeks back.
And this!!!! Just entered the 160 db club!!! Woohoo!!!! LOL
Another competitor took this one, Cody's face is priceless!!!
Brought this home from the show.
Evo X build log
Here is how the truck sits after all the additional weight
Well since I have such large current demand and large voltage drop(10.5 volts)...Let's UPGRADE!!! YA!!!
Lots of wire here.
That positive terminal is hurtin....I can hear it crying....LOL
Running cable for the quad alt kit, 4 pos and 4 neg 1/0 stinger, all thru firewall!!!
Tejcurrent Quad alt kit and (3) 230 amp alt(top row) - I also fabbed up lexan heat shield for the front battery you can see in the pic below
Idle video of Quad kit.
http://www.youtube.com/watch?v=bPtULNC7Iv8&feature=mfu_in_order&playnext=1&videos=M78I7Q5mVvc
Future home of many batteries!!!!
Evo X build log
  • Who's Online   1 Member, 0 Anonymous, 1550 Guests (See full list)
