Torres' Box Tuning Calculator - Updated 8/18
Torres
UPDATED!!! finally got everything worked out that i wanted, plus a neat addition or two.
***When downloading, make sure it is saved with a .exe file extension, or it will not open properly. the 'Open with...' window will pop up otherwise*** (thanks gottahavbass917 and a user from another forum :))
To do this, go to the folder that the calculator is in and click tools in the toolbar at the top (click alt on the keyboard if you can't see the toolbar). Then click folder options. then click the view tab, and in the advanced settings window, there's a check box that says 'hide extensions for known file types'. Uncheck that and you will see the .uexe file extension on the calculator. Take out that U and save it (just as .exe) and it should work. Now you can go back and recheck the check box and hide known file types.
Also, should have said this from the get-go (I apologize) but thanks to Razor5070 for the help when i got stuck :)
Here's the new look:
Posted Image
In a week or so, as long as I can make completely sure all kinks are worked out, I'm going to redo the layout and upload that as another download. The original one will stay up as well, but it'll be easier to fix anything and then redo the layout and upload rather than adjusting everything to fix and then readjusting everything. It'll be more for widescreen users and everything should be accessible from the get-go.
Changelog:
-Metric in millimeters and centimeters
-Changeable backgrounds and fonts. View the help window for more info.
-Individual inputs for bracing and subwoofer displacement
-User input for port thickness
-Added port ratio box
-Port area range removed
-Screen Shot button added. Will open MS paint and can save from there.
Here's the download link to the program:
Click to download Torres' Box Tuning Calculator
***you'll need the most up to date .net framwork for this program to work. click this link to get it***
.NET Framework
If you're .NET is up to date, and you're still having troubles opening the calculator, check to make sure it downloaded as a .exe file. It should have normally, but for some it may not. Rename it with a .exe format and it should work. Thanks to pervitizm for finding this solution.
For Mac users:
This is a windows based program, so it will not work on macs from a fresh download. You'll need to use either parallels, virtualbox, VMWare fusion, or wine.
There's port cut sheets in there, but one thing i did NOT include are cut sheets on how to cut the port if it bends. There's too many different ways to cut the sheets, and the coding to go into that would be too tedious to deal with. Maybe at another time down the road. Right now I want to get it uploaded and not have something silly holding it back. Plus, if you're building a speaker box, I'm sure you can go take some measurements in the box and see what the port should be :)
READ THE FAQ/HELP!!!!
I've answered questions repetitively because the help window was not read. So read that first please.
I've also included a FAQ/tip sheet with it this time around. So if you get confused with something, click there first. If you're STILL confused, send me a PM with any questions. With that being said, I'm still going to paste all the contents of the FAQ here.
Box Frequency Tuning Calculator - FAQ/Tip Guide
1 - First and foremost, the RE calculator is *not* spot on, and is limited in design, so no, it will not match this calculator.
2 - When doing an oddly shaped box such as a fiberglass box, or you know the volume of a certain box you have in mind
that you want to build, put the net volume in the 'Desired Net Volume' box. This will bypass all dimensions entered
preventing you from having to guess dimensions to get a certain net volume and will allow you to tinker with different
port sizes and tuning. So if you know you want a box with 4 cubic feet of net volume, enter '4' into that box and it
will allow you to adjust tuning accordingly to that specific volume. Keep in mind that any displacement nor port volume
is NOT subtracted from this total. Any number in this box will override any number in the 'Desired Gross Volume' box.
3 - The 'Desired Gross Volume' box acts much like the 'Desired Net Volume' box, except all displacements are taken into
effect.
4 - If the '# of ports' box is greater than 0, that will automatically get taken into effect and the calculator will ignore the
dimensions for slot ports.
5 - The '# of Common Port Walls' box refers to how many sides of the box are going to act as sides of the port. This is
done by looking at the port head on and counting how many sides of the box that face of the port uses as the port
walls. The port inside the box has nothing to do with the common port walls. Please refer to the links below for
examples.
6 - Aero ports have a defaulted thickness of 3/16" -- couldn't decide whether to use 1/8" or 1/4" so I went in the middle.
7 - Port length uses the box wall or baffle(s) as part of the port length. So a port that is 10" long with one baffle using .75"
wood will only need to be 9.25" long since the box wall or baffle(s) will account for the other .75". If using two baffles,
then it would be 8.5" long as the baffle will account for 1.5" of port length and so on.
8 - When using multiple ports, whether they be round or rectangular ports, the port length MUST be the same for each
port. The port length does **NOT** get divided among the ports. This will affect your net volume and severely
raise your tuning.
9 - Program resolution is set to 840 pixels in width and 780 pixels in height. Try to stay within this resolution for custom
backgrounds or program may lag. Using .png files will also help prevent program lag.
10 - The extra baffle box should only have a value if you plan on using multiple baffles. Leave blank or a zero if you are
only going to use a single baffle.
11 - Regular square/rectangle boxes do not need any numbers entered into the 'Height 2' or 'Depth 2' boxes.
12 - Pressing 'Enter' will prompt the program to print.
13 - PLEASE NOTE: 'Physical port length' refers to the length of the wood itself needed to build the port. This is NOT the
same as the effective port, or the port you entered into the port length box that the box will 'see'. You measure
on the inside of the port (against the port wall) to measure the physical port, in the same way you measure down
the middle of the port to get your actual, or effective, port length.
14 - When doing an external port, the full length of the port must be entered into the port length box. Then the length of
the external port in the 'External Port' box. This way the proper port length (the Port Length box) will be used for
the equation, and the proper volume will be added to the net volume (the volume of the external section of the port)
for proper tuning.
15 - On the cut sheets of boxes with different depths and heights, you'll notice 'H1' or 'D2' next to the measurements.
These represent which dimension is which. Here are two pictures to illustrate:
Box with one height, but two different depths:
Posted Image
Box with two heights and two different depths:
Posted Image
--The following are links that illustrate how each ported box is taken into effect in the calculator (sub and port position can be upwards with the same effect):
1 - Port with 0 common walls:
Posted Image
2 - Slot port with 1 common wall:
Posted Image
3 - Slot port with 2 common walls:
Posted Image
4 - Slot port with 3 common walls:
Posted Image
--The images were made with Google Sketchup. Free to download: http://sketchup.google.com/
Should be 99% debugged (I think). But after staring at the same coding for so long, things are bound to slip by. So IF you do find something that seems out of place, PM me about it please. Only if you're certain about it. I dont want to go check something or explain how it's done several times over because it may be coded a certain way that you may be thinking differently. That'd be too tedious for me to do constantly.
Hope you guys like it the update :)
And if you appreciate my work, buy me a beer :D
https://www.paypal.c...d=KSKSZ2SBUV6RS
updated. i added 4 buttons to choose wood thickness. .75", 1", 1.5", and 2". figured that'd be the most extent of this at least.
also added a box to display surface area of the port. link is in first post :)
  • 2 months later...
updated again. added a box to show the range of surface area of port you should have in conjunction to box volume. based on 12-16" per cubic foot to help get an idea of how much area to use without having to calculate it manually. nothing major...just something to look at if you need it :)
  • 1 month later...
hey exposport, your box calc works great for me, ...In calculating for the end port correction, I just add half of the port width to the actual length of the port....for example my port width is 3" and the length of the port is 16", what I do is to get half of 3", which is 1.5" and add that to the length of the port which is 16", to get the total port length with end port correction of 17.5"...will this formula work for your box calc? I'm quite confused on your post on the first page regarding your calculation for the end port.....hope you can enlighten me with this one....thanks....
when doing a slot port...just check the slot port box in the program and it will automatically figure in half of the port height for you into the tuning :) make sure to use *port height* as the distance from the port wall to the box wall. otherwise it will use a much longer number for end correction.
so your port *height* would need to be 3". then enter in the port width. then enter 16" for port length. check the 'slot port' check box and it'll automatically add 1.5" to the port length inside the calculations :)
  • 2 months later...
it's there because he sub 'sees' that extra little bit of port. so while it's not physically there, the port still acts that much longer
Okayyy, How do I take it into account when building the box though? say for instance 8" port length gives me 35hz and the correction is -9.5"
my motto: hit it, quit it, never admit it :D
  • Who's Online   0 Members, 0 Anonymous, 1273 Guests (See full list)
