Okay, now that everything is in, time for some testing on my part.
History:
The belt on my alternator has been slipping (the load is 4x the stock load on the belt) and I need to solve that problem.
Today's testing will include
1) Belt timing test, by hooking to spark plugs and usingthat strobe light timing thing to find out where it's slipping (my dad's equipment, I forgot the name)
2) Check all engine grounds, etc. for tight connections and etc.
3) Check voltage drop throughout all wires and make sure I don't need to upgrade to 2/0 from batt's to the amp (its about a foot only...)
4) Use a clamp-on ampeter (sp) to test alternator output. if less than 250 (significantly) i know the belt is slipping
5) Use my new (got it for christmas) DMM's high/low feature to check for lowest voltage at batts, and at amp while full tilting
6)Check RCA voltage and make sure both channels are equal at exactly 6 volts
7) GET PICS AND VIDS FOR YOU GUYS
Edited by Bass4Lyfe
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
if you did the big3 and left the stock + batt to alt wire, dont forget to put that in the clamp too.
DC.jpgDC POWER
good point, thanks man
~Matthew
Results
DMM set on "min", amplifier ON car ON MIN VOLTS = 12.13 VDC
Alt output around 200 amps, belt slipping a lot so I am missing out on that extra 50 amps
any ideas?? the belt is TIGHT
voltage drop @ 300amps from rear battery to amplifier is .08v
RCA RMS voltage (AC) into amp, from line driver, 5-7. 10.3 v on a sin wave 35 hz (is this bad?)
EDIT
vids TAKEN have to go to work to upload, so 2morow
Edited by Bass4Lyfe
~Matthew
i don't think its the belt but if you want replace it get the goodyear gatorback belt from autozone. i replaced my stock belt with it and its been runnin good ever since. no squeeling at startup
Edited by kentb
if its not the belt what should i do, to fix the problem?
and i will replace w/ gator back on monday
~Matthew
Gatorback ftw- then see if it keeps slipping
-Drew
uhoh_45 said:
kk, thanks a lot drew!
ps
i wanna visit u soon!!
~Matthew
u hitt'n on me now?
-Drew
**gotta buy me dinner first
Edited by Noobtastic14
hahahahaha
no
~Matthew
  • Who's Online   0 Members, 0 Anonymous, 832 Guests (See full list)
