2 Amps with 2 0g power inputs each, in a 2001 crown vic p71
I am most likely going to be running (2) Powerbass XTA-5000ds in my next build running (2) DC Lvl 5 18"s. I will be replacing the stock alternator with a high output 250amp and also adding a second highoutput 250amp alternator. I will be running 3-4 Kinetik 2400s batteries. My question is how I should run all the power wire (0g). Should I run 1 line of 0 guage from each alternator to its own batterys or should I just group all the batteries together? Then 2 runs of 0 guage from the rear batteries to each amp?
Just trying to price all the wiring and fuses out.
Thanks
Grouping the batts together IMO is the easiest and most effective way... Use buss bars if possible, just makes things easier.
Pioneer AVIC-N2
Bus bars, made my life so much easier, isnt that hard, and pretty cheap
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
i got mine from here great price on stuff
I got aluminum and then drilled and tapped all the bolt holes.
http://www.onlinemetalsupply.com/
*1) AudioQue 20k
  • Who's Online   0 Members, 0 Anonymous, 976 Guests (See full list)
