Robola 46's BERYLLIUM BMW 323ci.
well, on behalf of rbola 46, i decided he needed an UBL...even though there isnt a ton of chit chat in his build...he still deserves it..so here we go.
PLEASE LEAVE ALL COMMENTS HERE:
http://www.stevemeadedesigns.com/board/ind...showtopic=57269
the following are just copies of his post...ENJOY!!
:spiteful::spiteful: A little word of me...
I was always interesting in car audio.It Is my biggest hobby , every time i got i spend it on the car.12 year ago i had a fiat 500.I whurk 3 years one the car for restoration it and building a stereo in it..I did some competition wit it and from the 19 games i did I when 17 first ..My second contest was at the european final in PARIS en i was second afther THOMAS (swipe) WESTMAN from sweden.The next year I was in BIRMINGHAM ( IASCA FINAL).I was first in my class and the first place BEST OF INSTAL.Then i make a decision to stop white contest.I was one my highest level .
In the years i was competing i was always working on the car for making it better and better.Evry minit I got I spend on the car..
there was always the presure of performing beter . When i began on this project i make the decision ,to make something beautiful en having fun and now presure.I NOT going to compete whit this car..Not whit the speakers on the A pillar, and not with the plexy sub box.
Writing this is not so simple for me.I understand, and speak english but that's everything.i can't write englisch i am translating my words with the help off a translation program.It's not so simple for me to tell everthing in detail. But i hope you will understand.I realy hope to get some comments good or bad.everybody had his opinion about car stereo.
This is the car.
:drinks::drinks::drinks::drinks:
i likes me some audio stuff...
There is still some adaption work.
This will be the Sub-box.
The piece I wanted to cover in Carbonkevlar, I painted black, to be sure the layer underneath won't show.
milled some rings to put the woofers in.
Here a picture of the bottomside, where he made wholes , to let the sound flow outside.
Still some more polyester work to do.
Did some preparation to stretch the cloth nicely.
The wholes you can see in the alu, don't worry about it.
It'll be covered in CF..
The next thing on the list is something very difficult.
The connections of the speakers he'll make in copper, of 5mm thickness.
Cables are so boring
some cupper
5mm thickness, more didn't fit in the speaker.
Copper connections are ready.
made a model first, took a mold, and fold it the same way.
Sawed it all, rubbed it, and polished.
On this picture you can see he putt a whole in the bottomside to connect the cables.
The cupper wil go to the middle, so I made a alu plated where the bars fitt right on in.
alu triangles bade in a little CF.
some more CF.
This is the bottom plate where the box is put on.
sprayed it in black offcourse, don't want the colour of the wood come throu
Varnished it for the first time, rubbed some more, varnished, rubbed, varnished, rubbed, ...........
started to make the bottomplate. She will be around the BOX and rest on the chassis of the car. did it as good as possible. Leveled it with waterleveler.
Once this plate is right, you take the messurements always from this plate, so it has to be 100% correcT.
milled to upperboard
Started to make a hinge. He went to see the store, but they didn't had what he needed. So got some aluminium ..
The meaning of this hinge, is that the amplifier can go up. So the crowbar needed to be something nice.
Cause the crowbar wil be very shot/small, he made it strong enought. (15mm thickness)
there are nicer things in life to do, but when it's finished, it was worth the work in his eyes.
Against the alu tube, he's going to weld a piece to, where he can hook the amp on.
Then I started to tair apart the Alpine CD player.
Did away the front, and made some trolleys to fasten the thing.
here you can see the front of the CD player
The ALU- box where the amp should come is foreseen with the hinge.
This one, he screwed on. I going to try it'l go this way.
If not, he can always weld it on...
I doesn't want to try it now, cause he's afraid it all bend of the heat.
But it's a final option...
Will look like......
put some movement in the amp.
Made a fiberglass plate.
Here will be some change soon, but you have to start somewhere.
found some vents that you can take from each other.
These are from aluminium, but the frame they're in, goes in the bin.
There will be an -minor modded- version of it
2 pieces to place in the vents, so the cooling on the amp will be better.
Some chinese sticks
put them together
painted with polyester/fiberglass
rubbed and filled, filled and rubbed
this will be carbonized
The pieces are finally done.
all that work, pppfffffff, but it was worth it .
Here's a picture from the front. You can see a V where everythings slides into.
Then he fiberglassed a little alu piece that is fastened bigtime.
In the whole those things are layed into, fiberglassed a firm alu bridge, and there the backside slides into.
These things have to come out really fast, cause his GPS and CD loader is behind it.
I made a grill, to cover the sub-box.
The frame es milled out of MDF wood.
Here you can see the top of the upper ring. This one, you will see, and will be covered in Carbon
On the picture, you can see he miled a little ditch.
covering the frame in Carbon
  • Who's Online   0 Members, 0 Anonymous, 1010 Guests (See full list)
