Hi, I am running 2 strands of 1/0 wire from the front to rear in my truck. The amp's fuse rating is 300a. Should I install 150a fuses in each of the runs of 1/0, or 300a fuses in both?
Also, I am installing a DC Power 270xp alternator in my truck, along with the big 3, etc. Is is mandatory to run an inline fuse off the alt to the battery? And if so, what fuse rating should I go with, I was thinking 300a.
Thank you.
-Dan Kasun
05' Dodge Ram 1500 QCSB Hemi Blow-thru build in progress.
2 RD HW18's, RD D9, 5 Deka 9a31's, 6th order blow-thru box, Eclipse 7200mkii HU, 140' Knu Kollossus wire. DC Power 270xp Alt, Etc.
i would run 200a or higher for both wires
the 150a fuses could limit the amp a little. remember fuses are current limiters.
what amp btw?
no fuse from alt to battery.
just make sure the connnection is strong
what amp btw?
Either my RD 3250 or an AQ3500D, both recommend a 300a fuse.
-Dan Kasun
what amp btw?
And I already have enough 300a fuses, but I'd need to order some lesser amp ones. Will it be safe running both 300a?
-Dan Kasun
yea i would stick with the 300a per 0 gauge and no fuse from alt to batt.
as always make sure you have strong connections.
what kind of 0gauge do you have?
EDIT:meant stick wit 300 not 200 since you already have them
Edited by brewer_brewer
you are supposed to fuse for the wire not the amp, the 300 amp fuse is for the rating of wire not the amp.
ie if you run 10 runs of 1/0 you need 10 300 amp fuses
Edited by Accordman
yea i would stick with the 200a per 0 gauge and no fuse from alt to batt.
All my terminal connections are soldered and heat shrink wrapped.
I am running Shok CCA 1/0.
-Dan Kasun
u would fuse it all with 300 amp fuses and yes the alt 2
alt----fuse(300) -----fuse(300)----battery---fuse on frist 1/0 (300)-----300 fuse in rear if u have batterys then the same this as the frist run
edit: accordman beat me 2 it
Edited by 01zx3
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
i dont have fuse for MY alt.
my bad. just saw that you have a ho alt.
yea fuse that with 300 so you don't melt that wire.
  • Who's Online   0 Members, 0 Anonymous, 416 Guests (See full list)
