I will be using bolts for the speaker wire, ( never done it before)meaning wire with terminal on inside, and wire with terminal outside, the box will be carpeted so.....
1. will the current flow cause a problem with the carpet? (ex heat causing fire or burning of the carpet)
2. The nuts and bolts are all Stainless Steel, is that ok for this use?
3. Will these affect the ohm load that the amp sees? (imp rise?)
Thank you in advance
Sry if these are dumb ?'s, I used the search bar, but I didnt get much that really helped.
1. Will the current flow cause a problem with the carpet? (ex heat causing fire or burning of the carpet)
I doubt it but i'd put a washer under the wire and then the nut over it so the wire doest touch the carpet
Yes
No idea...
My Babies
97 2.5 Avenger, 92 5.0 Fox, 97 2.0 Turbo GST Eclipse, 00 2.0 Jetta, 06 GSXR 600, 98 CBR 600, 01 GSXF 600, 93 CBR 900RR
Wilwoods dont slow your car down, they slow the earth down under your car...remember that next time you slam your brakes, you may spill my drink.
ive never seen it on carpet but people use those bolts all the time. nothing wrong with it. im sure it wont cause a fire.
Yes
No idea...
Well I was Thinking of this, on the outside of the box, it would go washer, nut, Ring, Nut
Edited by Crump
lol dude, a washer would be the same thing as the wire. unless its rubber.
lol good point, wasnt thinkin about that.
I think itll be fine with no washers but if wanna have something to make it feel safer to you, get you some of these... http://www.crazypc.com/products/PQ4-8305.html
Or just cut the carpet around the bolts away a good bit.
Edited by Street
My Babies
why not just leave the bolt out and run the wire through the hole?
dont know how to use a soldering iron?
  • Who's Online   0 Members, 0 Anonymous, 1550 Guests (See full list)
