NEED AMPS? Twin 2010 Hifonics Brutus BXi 1210Ds
For Sale are two (2) 2010 Hifonics Brutus 1210D monoblock amplifiers. These would be great amps to push someone's two-sub set up as they have phase adjustment, subsonic filter, remote bass, etc.
One amplifer is brand new and the other has been running two 12s at 2 ohms for a couple of days. Both amps are 10/10 Cosmetic and Function.
PRICE: $185 SHIPPED (each) to lower 48
"Brutus BXI amplifiers are recognized the world over as some of the best subwoofer amplifiers in their class. For SPL, the Super D-Class® featured in Brutus amps is certain to satisfy. Hifonics® has perfected Super D-Class digital chip-set technology to provide an extremely efficient, low temperature, high amplification system that others only dream about. The result is a smooth digital to analog conversion with low distortion, even at high listening levels.
All are 1-Ohm stable, but also run at 4- or 2-Ohms for a much tighter bass response. Simply put, watt for watt, a Brutus amplifier produces more output with less impact on a car's battery and charging system, than other amps available today. Translated into cost, that's more wattage output with less battery current used to equaling more watts per dollar."
HIFONICS BRUTUS BXi1210d Amplifer Specifications:
RMS Power Output: 1 x 450 W @ 4 Ohms
RMS Power Output: 1 x 900 W @ 2 Ohms
RMS Power Output: 1 x 1200 W @ 1 Ohm
Protection: DC, Speaker Short, Thermal, Overload
Power Supply MOSFET
Audio Output MOSFET
Dampening Factor: >250
Signal To Noise Ratio (A-weighted): >95dB
Variable Input Level Control (unbalanced): 0.2V - 9V
Input Level Control (balanced): 0.04V - 18V
Input Impedance (un-balanced): 47k-Ohm
Input Impedance (balanced): 20k-Ohm
Power / Diagnostic L.E.D.
Variable Low Pass Filter / 24dB: 35Hz - 250Hz
Variable Subsonic Filter / 24dB: 15Hz - 35Hz
Variable Bass EQ: 0dB - +10dB
Phase Shift (0 - +180 degrees)
Unbalanced Inputs (RCA)
Balanced Inputs (DIN)
Line Output (RCA)
Speaker Terminals (molded): 12ga
Power/Ground Terminals (molded): 4ga
Remote Bass Module: HFR-3
Parametric bass EQ with 45Hz bass boost and variable control from 0db to 10db
Variable Low Pass, Subsonic Filter, Phase Shift and Level Control
Balanced line input for MX accessories and line drivers
Bass Remote included
Built-In System Diagnostics protects from short circuits, over load, thermal overheat and DC Offset.
Dimensions 11.42" x 2.52" x 9.45"
Sorry about the terrible pictures, guys.
Nice amps, man! I just picked one of these up locally and it's awesome. Whoever buys these from you will NOT be disappointed!
1996 Vw Jetta
Crunch 1500watt
1- Kicker 15" L7 @ 1ohm in a 4cu. ft. Ported Enclosure Tuned to 32Hz.
4- 6.5" Menace Door Speakers &
2- Menace super tweeters in the dash
139.11db @ 40hz (6/2010..old amp setup)
current hogs or pritty efficent?
im thinkin bout runnin a hifonics sub amp to go with my 4ch so it will all match n i can throw my memphis stuff in the geo
if i had my tax money right now ied get one off of u but i had to refile em twice so i dunno when i will get my money
but if u still have these sometime later i damn sure want one
did u put that lil foam piece over the hifonics logo to keep the brightness down or did it come like that?
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
I know, these are some pretty nice little amps. One of them running at 2 ohms (450 watts per sub) on 2 12s sounds great and has enough output on low bass to wobble the roof and windows of the truck.
The REALLY impressive thing is the phase adjustment, variable bass boost, and remote bass though! If you run two of these, that becomes a very valuable tool.
These amps come with that little foam peice on top. That's to protect them during shipping, I guess. Since these will shipped, I didn't remove it. The amp in the truck stays ice cold, so it's no worry about it melting or anything.
As far as current, I can't really tell right now. It's running 2 ohms on a 250 amp alternator. It has an 80 amp fuse, if that tells you anything. It will probably draw more than that only if you try to run it at 1/2 Ohm or something.
  • Who's Online   0 Members, 0 Anonymous, 1078 Guests (See full list)
