4 Channel Amp Question
55437Audio
Hey so trying to set up my Mid Bass and tweeters to my deck and I want to set the mid bass drivers to a 4 channel amp at 2 ohms final, and leave my stock wires to the doors for the tweeters...
What I want to know is can I use the stock wiring from my deck for the (4) tweeters, or does the 4 channel Rca from Deck eliminate those outputs?
I will have (4) 3 Ohm Tweeters 50 rms each, And (4) Mid Bass at either 4-8 Ohms at 125Rms each no set amp yet, Any recommended way to hook these up to get sufficient power to all?
(With out using 2 amps)
Thanks, Austin
My First Build on SMD (Blow Through)
2004 Ford F-350 SD Lariat
Pioneer 3200BT DVD Deck
Infinity Reference Components not powered
Bully Dog Gauge Cluster Pyro, Turbo, Trans
SF3 SCT Tuner W/Customs
If you can't Join em' Crush em'
anyone
2002 Mitsubishi Lancer
3-18" Mayhem Subs
Pioneer AVH-6300BT
1-10K DC Audio Amplifier
1-5K DC Audio Amplifier
3-Pioneer GM-D9500
6-Kinetik HC2400
2-XS Power D3100
1-Kinetik HC1400
Ohio Gen 160-180 amp HO Alternator
  • Who's Online   0 Members, 0 Anonymous, 639 Guests (See full list)
