ok i just purchased the hifonics brutus 1700.1
have my two dvc 2 ohm subs wired down to 2 ohm for the 1200 rms they can handle.
my rockford 500 i took out before when i my hu was turned to 15 was moving them nice.
the brutus has to have the hu turned up to like 22. is that normal?
and also the rockford said it paralleled internally. the brutus doesnt say that but the wiring diagram it came with shows exactly how i have them wired. so now im confused cause there is 2 sets of + and 2 sets of - on the amp with nothing letting me know it parallels inside.
if you understand this at all i just am trying to understand why going from 500 to 1200 its takes more volume.
What model hifonics? You were probably getting more clean power from the rf. Set your gains with a dmm to help from clipping and to get clean power from hifonics idk what you mean by paralled internally. Its a mono amp so its bridged internally if that's what you mean
www.wooferwarehouse.com
Dmm will not help with cliping so don't give that info out...the only way 2 test for cliping is with a o-scope
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
What setting do you have on the amp as of right now? And compared to the rf amp?
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
keep in mind only the ends of the little dials are labled so i have no exact number.
i have the sub sonic around 30ish
low pass is prob 50ish
bass eq is half way up
level would be around 4ish
phase 0.
amp side shot
Turn low pass to the 12 oclock position that will put you closer to (~eighty) hz
Bass eq put at 2 oclock position, try that see how it does.
At 4ish for level that would be at a 1v preout setting, just guessing, so you must have a pretty weak headunit for preout voltage?
Edited by AMI CUSTOMS
Evo X build log
ok what we have here is a failure to communicate.
those numbers i gave you is what i would guess they would be if they were labeled. not like looking at them on a clock.
when i said 4ish i meant the level would be 4 volts. not 4 oclock.
From the picture you sent me. You can't compare your old amp to this out, do you know what the voltage range is on the old amp on the gain, the hifi say 9v - 0.2 volt is your rf the same? Likely not or you have something else changed between the two.
Evo X build log
