what amp for a 15" Fi X
HotRodHam
Im getting a single 2 ohm 15" Fi X with the BP power option.
box is going to be tuned to 30Hz... thought ide tell you even though you don't need to know for the amp.
SINGLE 2 | SINGLE 4
Fs: 33.3 Hz | 33.4 Hz
Re: 1.9 Ohms/coil | 2.9 Ohms/coil
Qms: 6.02 | 6.05
Qes: .51 | .51
Qts: .47 | .47
Mms: 148.1g | 146.7g
Cms: 1.5mm/N | 1.5mm/N
Sd: 810cm^2 | 810cm^2
Vas: 141.4 l | 141.4 l
Spl: 91.9dB 1W/1m | 92.0dB 1W/1m
Bl: 10.8 N/A | 13.2 N/A
Xmax: 18mm | 18mm
Rms: 250W * | 250W *
Sealed box: 1.8-4 cuft | 1.8-4 cuft
Ported box: 3-5cuft | 3-5cuft
Sub OD: 15.625” | 15.625”
Cut ID: 14.125” | 14.125”
Mounting depth: 7.750” | 7.750”
Displacement: 0.10cuft | 0.10cuft
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
That will work, but you will need a single 4 ohm coil, not 2 ohm.
I would buy the kicker ZX300.1 from hifisoundconnection.com
$109 refurbed, $138 new
I have one in my silverado. Nice 300 watt amp. With this amp, you would want the 2 ohm coil.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • Who's Online   0 Members, 0 Anonymous, 922 Guests (See full list)
