protocaster69 Posted February 8, 2011 Report Posted February 8, 2011 I found a really good deal on one of these amps... They are 1 ohm stable... and supposedly monoblock... But they have 2 channels... Does that mean I can run 1 1ohm vc on each channel?
Guest Posted February 8, 2011 Report Posted February 8, 2011 its a 1 channel amp. it has 2 sets of speaker terminals to help make wiring easier. you can use EITHER + and EITHER - to wire up subwoofers. you can use one + and one -, or both. doesnt matter
protocaster69 Posted February 8, 2011 Author Report Posted February 8, 2011 So if I run each voicecoil to each "channel" itll still be a one ohm load in the end? I appreciate the help.. It kinda confused me a little..
Guest Posted February 8, 2011 Report Posted February 8, 2011 So if I run each voicecoil to each "channel" itll still be a one ohm load in the end? I appreciate the help.. It kinda confused me a little.. you can do that or wire the voice coils together on the subwoofer itself. either way it will end up the same (if you are wiring in parallel)
