I just bought an Audiocontrol Overdrive unit and i was wondering if i can use rca "Y" adapters on the output side and run two amps off of it ???
Depends on the output voltage of the unit and the input voltage of the amps.
Let's say the Overdrive outputs at 5 volts. And your 2 amps have a minimum input voltage of 2 volts. You'll be all set. But if the Overdrive only outputs at 3 volts, then each amp isn't going to have a strong enough input.
According to Google, the Overdrive has a knob on it that you can set to 2V, 5V, or 7.5V outputs. I'd personally set that knob to 7.5V if you plan on splitting the signal to 2 amps. Most amps like to see at least 2V inputs (if not more) so 3.75 volts should do each amp nicely.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
  • Who's Online   0 Members, 0 Anonymous, 4818 Guests (See full list)
