DC Sound Lab
Posted (edited)
Level 3 15" off a Crown/JBL BPX500.1 in my 06 honda civic sedan:
In need of some help box design wise. I'd like to do a ported box using aero ports through the rear deck so either sub fwd port up or sub back port up. I want it to be tuned between 32-35hz since i listen to a few types of music. Also I think my car peaks at around 50-52HZ not sure what factor that plays into the tuning of the port/box.
Dimensions would be around:
Width:40" max
Height 18" max
Depth: 11" (depth can be up to 24)
Issue is: using 2 6in aero ports will be to much port and 1 6in will not be enough.
SO I can either use:
3 4" ports w/ total port length 26" @ 32HZ
or find someone who makes a 7in port and use 1 7in port 26"L @34.54HZ
Input please :ehh:
Edited by jlh2003
what is the space between where the box will be placed and the rear deck.. If you have the space you can use the 2 6inch ports by making them half internal and externalports..
Jay
max height is 18", max width is 40", max depth is 28"
how long each were the 2 6" ports?
so the box could be 16.5H and that would leave 3-4" of external port room for the rear deck speaker grill to the box.
what exact specs were you using? I've been playing with it on the box building calculator
