I have 2 aq hdc3 12's copper. Looking to get a new amp and sell this tiny aq2200d. Should i go with the dc audio 5k or aq3500d?
BUT!!!!
So far when i buy that 5k or 3500 ill only have this electrical ---2 yellowtops, big 3, all 1/0 wire, and ill be buying an alt too, probably a 350+.
Will i be able to run either of those amps with the above electrical without hurting it? Just need pointers to which amp i should go with due to
electrical and subs, the subs really can take a beating ive ran them on a thunder elite 4000 or something i forgot, at my buddies shop and they really
take a sht kicking lol. thanks guys!
1998 GMC Jimmy 4 Dr.
-SINGER 275 Amp Alternator
-150 FT. Of 1/0 OFC (8 runs) 4 pos, 4 neg. Front-back.
-Audioque AQ2200D @ .5 ohm
-2 Audioque HDC3 18's Tuned to 27-29 HZ
-4 Clarion 6.5's
-2 Optima yellowtops
I personally think you'll be fine with either amp and that electrical....what ohm load will you be running? Just give it a shot......if the voltage is not looking too good.....add 1 or 2 more yellow tops :drink40:
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
1 ohm. just because i think 5k is enough for 2 hdc3 12's copper, and to help voltage better than .75 and .50 ect, and yeah ill add 1 or 2 more yellowes if it does look bad, but 1 ohm. I saw 4k move the hdc3;s and i think 4k is enough, but 5k even better ;)
-4 Clarion 6.5's
You should be just fine ;)
  • Who's Online   1 Member, 0 Anonymous, 1565 Guests (See full list)
