hey everybody Im trying to hookup my 6x9 rear deck speakers to my 2 channel amplifier. The speakers already come with tweeters I just want to hook up my amp to the tweeters that come with the speakers to power it. I already tried getting speaker wire, pos to pos, neg to neg from my amp straight to my speaker terminals but I get no sound. The speakers have bass but I get no sound from the tweeters? Do I need a Passive crossover? Notice I only want my rear deck tweeters activated thats why im using a 2 channel amp.
Posted (edited)
they could be blown
I doubt it I tried it with different speakers that I had and it still didnt work? I hear the tweeters come on wen I hookup the factory speaker terminal wires.
Edited by gotboom88
they could be blown
Um try switching the low pass switch to full pass or high pass
I already did I put the filter on my amp to HP. And still no sound? I drive a 01 honda prelude could it be that it already has a built in factory amp? I really dont know whats causing it not to play. I speaker cone gives out bass, but no sound whatsoever. Kind of like a speaker with bass but no sound.
Do u have a factory hu
No I have a Pioneer Premier head unit.
Can anybody just type a DIY or exact directions on how to run the wiring to my rear deck speakers to activate the tweeters? I want to make sure everything is hooked up right. <_<
Deck>RCA> amp output to speakers left and right make sure your not using the sub out put on the deck and yOu are plugged in to the front and rear RCA output and if they are running that 2 ch amp then make sure the cross over on the deck is not just set on LP only on the out puts but make sure you are using the Right RCA on the back o the deck
Thanks audioinnovationsfl. I bought the car a couple days ago and it was already wired up. Im not sure if the RCA's behind the rear deck are hooked up to the right output. Ill have to check into that. And my LP is set on 80hz on my hu thats probably why.
