ok here is some thing I would like some opinions on doing the big 3
Option 1 for positive post to alternator route cable along the area outside of the radiator.
Option 2 for positive post to alternator route cable along driver side fender area and along firewall away from engine and around air cleaner
and for ground
as all ways negative to engine block
but to ground to chassis I choose to ground at the strut tower because the other ground is rite on the fender of my car I could also use a small piece of 4 gauge cable for the fender in addition to grounding at the strut tower.
your feed back is appreciated
Edited by ROAD_DOG
i would try to make all you runs as short as you can. try to keep them away from moving parts . and high heat spots like the exaust. or places that it could wear a hole in the insulation.
i would choose option 2 due to me thinking that the wire casing will rub against the hood when you close it if you chose option 1
option 1 would be the better than option 2. i dont think all you grounds have to go directly to the batt. just ground the batt to the frame. and ground every thing eles there too. no need to run a ground to the block. the blocks already grounded. i would use conduit on all the power wires.
well i figured that the wires not going right in that spot. probly just showing it there so we can see it. or atleast i would hope so lol
Edited by big dee
the big 3 is alt + to batt + then batt - to frame then batt - to engine block. you have 2 1/0 wires on the - terminal and 1 1/0 wire on the + terminal.
  • Who's Online   0 Members, 0 Anonymous, 696 Guests (See full list)
