Rockford Fosgate bd1000's X2
both in pretty good shape for there age. couple marks here and there but nothing that will affect its ability to perform. i dont have either bass remote or original boxes for them. you can still buy the bass remotes and also the bdsync cable to link these together on ebay for pretty cheap. these put out good power. i had like 5 or 6 of these and most of my birth sheets said 1100 up to almost 1400 rms.
both are in working order
Details:
Class bd technology
1000 watts x 1 at 2 ohms
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
100-amp fuse and fuse holder required
selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability.
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp.
NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance.
preamp outputs for easy connection to a second amplifier
wired remote control of Punch Bass (0-18 dB centered at 45 Hz) — gives you fingertip control of your bass impact
subsonic filter removes frequencies below the range of human hearing for increased efficiency
dimensions: 14-7/16"W (10-7/8" without endcaps) x 2-7/16"H x 9-7/8"D
not sure were to start off at for a price.
how about $ 200 shipped each or 375 shipped for both. throw me some offers if your interested might be able to work something out.
NO TRADES!!!!!!!
Edited by Loudcivic
2015 silverado crew cab
nothing atm but soon...
This topic is now closed to further replies.
