Pittcrew Posted February 26, 2011 Author Report Share Posted February 26, 2011 what type of car or truck is this box gonna be in? a 2001 toyota camry. Well i played around with the calculator and just pretty much winged the dimensions for what I think would fit in my trunk and it came out the first time with 6.322ft^3 i would do sub back port back UNLESS you wanted to do sub forward port thru the rear deck and sealed off from the trunk I'm probably just gonna do sub back port back since it's my first box I want to try to make things as simple as possible. Quote My build: 2001 Toyota Camry two 12" Kicker l7 Solo-Barics Kicker 1500ZX Amp 0-AG Wiring Pioneer DEH-3300UB Head-Unit Link to comment Share on other sites More sharing options...
matt402 Posted February 26, 2011 Report Share Posted February 26, 2011 how tall is ur trunk? u would prolly have to face the sub up im guessing. i wouldnt do an 18 in a trunk, but thats just me... . Quote Link to comment Share on other sites More sharing options...
Pittcrew Posted February 26, 2011 Author Report Share Posted February 26, 2011 how tall is ur trunk? u would prolly have to face the sub up im guessing. i wouldnt do an 18 in a trunk, but thats just me... . oh yeah that's true. I'll have to measure my trunk tomorrow. How would facing the sub up affect it though? Quote My build: 2001 Toyota Camry two 12" Kicker l7 Solo-Barics Kicker 1500ZX Amp 0-AG Wiring Pioneer DEH-3300UB Head-Unit Link to comment Share on other sites More sharing options...
Vitacy Posted February 26, 2011 Report Share Posted February 26, 2011 Pitt also make sure you can fit it through youre trunk opening or from where the back seats are.. Because if you can't that means you either have to build the box in the trunk or gonna have to sacrifice the back seats and seal you're trunk like I have to because I forget about putting the box in the trunk... Lol Quote Link to comment Share on other sites More sharing options...
uhoh_45 Posted February 26, 2011 Report Share Posted February 26, 2011 do you have the sub yet? Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
Vitacy Posted February 26, 2011 Report Share Posted February 26, 2011 Facing the sub up ain't bad. It's like the in between from sub fwd and sub back. Like the sub back gives it more of a low end, forward gives better higher notes, and up gives you a happy medium. That's how it is with my car anyways.. Quote Link to comment Share on other sites More sharing options...
Pittcrew Posted February 26, 2011 Author Report Share Posted February 26, 2011 Pitt also make sure you can fit it through youre trunk opening or from where the back seats are.. Because if you can't that means you either have to build the box in the trunk or gonna have to sacrifice the back seats and seal you're trunk like I have to because I forget about putting the box in the trunk... Lol yeah that shouldn't be an issue I don't think. My trunk is pretty big and the seats go completely down also. Quote My build: 2001 Toyota Camry two 12" Kicker l7 Solo-Barics Kicker 1500ZX Amp 0-AG Wiring Pioneer DEH-3300UB Head-Unit Link to comment Share on other sites More sharing options...
Pittcrew Posted February 26, 2011 Author Report Share Posted February 26, 2011 this isnt my car but it's the same kind, different year but it's pretty much how my trunk looks http://o.aolcdn.com/commerce/images/toyota_07camry_trunk_Large.jpg Quote My build: 2001 Toyota Camry two 12" Kicker l7 Solo-Barics Kicker 1500ZX Amp 0-AG Wiring Pioneer DEH-3300UB Head-Unit Link to comment Share on other sites More sharing options...
uhoh_45 Posted February 26, 2011 Report Share Posted February 26, 2011 this is a celica build with an 18 Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
Vitacy Posted February 26, 2011 Report Share Posted February 26, 2011 You should be fine. Just to be safe I would get some cardboard or something else that would be the rough size of you're box to see just to be safe. Quote Link to comment Share on other sites More sharing options...
