what type of car or truck is this box gonna be in?
a 2001 toyota camry. Well i played around with the calculator and just pretty much winged the dimensions for what I think would fit in my trunk and it came out the first time with 6.322ft^3
i would do sub back port back UNLESS you wanted to do sub forward port thru the rear deck and sealed off from the trunk
I'm probably just gonna do sub back port back since it's my first box I want to try to make things as simple as possible.
My build:
2001 Toyota Camry
two 12" Kicker l7 Solo-Barics
Kicker 1500ZX Amp
0-AG Wiring
Pioneer DEH-3300UB Head-Unit
how tall is ur trunk? u would prolly have to face the sub up im guessing.
i wouldnt do an 18 in a trunk, but thats just me... :trippy: .
oh yeah that's true. I'll have to measure my trunk tomorrow. How would facing the sub up affect it though?
My build:
2001 Toyota Camry
Kicker 1500ZX Amp
0-AG Wiring
Pitt also make sure you can fit it through youre trunk opening or from where the back seats are.. Because if you can't that means you either have to build the box in the trunk or gonna have to sacrifice the back seats and seal you're trunk like I have to because I forget about putting the box in the trunk... Lol
do you have the sub yet?
R.I.P!
(Nov-29-2009)
92 explorer
current build
Facing the sub up ain't bad. It's like the in between from sub fwd and sub back. Like the sub back gives it more of a low end, forward gives better higher notes, and up gives you a happy medium. That's how it is with my car anyways..
yeah that shouldn't be an issue I don't think. My trunk is pretty big and the seats go completely down also.
My build:
2001 Toyota Camry
Kicker 1500ZX Amp
0-AG Wiring
R.I.P!
(Nov-29-2009)
92 explorer
current build
