cichlidfort Posted March 9, 2011 Report Share Posted March 9, 2011 What's the true wattage of a Crunch PRZA 1500.1 at 1 ohm? I know its not the best amp in the world. It's for a younger friend. Quote 2008 Chevy Impala (undercover cop style) Setup in the makings Link to comment Share on other sites More sharing options...
cc_audio Posted March 9, 2011 Report Share Posted March 9, 2011 What's the true wattage of a Crunch PRZA 1500.1 at 1 ohm? I know its not the best amp in the world. It's for a younger friend. 120A worth of fusing, multiplied by working voltage. (120x12.5=1500W) take 1500W by its efficiency, which I use 70% as a standard. (0.7x1500=1050W). So, that amp should make at least 1000W RMS. Quote It's all gone! The Celica Build Feedback If I buy something from you, DO NOT USE FEDEX! Link to comment Share on other sites More sharing options...
kbsmoker Posted March 9, 2011 Report Share Posted March 9, 2011 If its the same as a P1500.1...less than 700rms. Atleast that's what I clamped @ 1.4ohms Quote www.dcsoundlab.comyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3 SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator Link to comment Share on other sites More sharing options...
Guest Posted March 9, 2011 Report Share Posted March 9, 2011 What's the true wattage of a Crunch PRZA 1500.1 at 1 ohm? I know its not the best amp in the world. It's for a younger friend. 120A worth of fusing, multiplied by working voltage. (120x12.5=1500W) take 1500W by its efficiency, which I use 70% as a standard. (0.7x1500=1050W). So, that amp should make at least 1000W RMS. basically Quote Link to comment Share on other sites More sharing options...
