bigjdawg Posted March 11, 2011 Report Posted March 11, 2011 first off i wanna say thank you to steve meade AND all the members.this forum is exactly what i was looking for. now to my question but first the specs of my system so knowledgeable persons can know what im working with (on a low budget)and know what i can do with it. currently i have installed: *amp-kenwood KAC-9105D(i have the model right before this ,kac-9104D which is the exact same specs) Performance Series Class D Mono Power Amplifier 500 W x 1 RMS Watts per channel @ 4 ohms, 1% THD+N 75 dBA Signal to Noise Ratio (Reference: 1 Watt into 4 ohms) Max Power Output 1800 W Rated Power Output 14.4 V 500 W x 1 (4Ω) (20 Hz - 200 Hz, 1.0% THD) 900 W x 1 (2Ω) (100 Hz, 1.0% THD) Frequency Response 10-200Hz(±1dB) Input Sensitivity 0.2 V - 5.0 V (MIN-MAX) Input Impedance 10 kΩ Signal to Noise Ratio 100 dB Low Pass Filter Frequency (-12 dB/oct.) 50 Hz - 200 Hz (variable) Low-Pass Filter Frequency High Pass Filter Frequency - Dimensions (W x H x D) 350 x 59 x 238 mm (13-3/4 x 2-5/16 x 9-3/8) *subs- in a double bottom slot ported box tuned to (i believe) 35hz with 2sq ft chambers for each sub(2) kenwood-KFC-W3012 Performance Series 12" Subwoofer • MAX POWER 1200W • 12" Woofer with 4-ohm voice coil • Urethane Surround • Dragon Spider Design • 2-Layer Voice Coil Design • Dual Magnet Drive • 8AWG Wire Capable Push Terminals • Frequency Response: 39-300 Hz • Sensitivity: 86 dB • Mounting depth: 6-3/16" SPECIFICATIONS: • Peak Input Power: 1200W • Rated Input Power: 400W • Impedance: 4 Ohms • Sensitivity: 86dB • Free-Air Resonance: 32Hz • Frequency Response: 39Hz – 300Hz ok, thats what i have now , and a kenwood HU pushing kenwood 6x8s & x9's. i have 2 more of the same kfc subs(12's) on the way and i was wanting to run all 4 . i know id be under powering them but thats better than over right? i will be getting another identical amp later on but i wanna know if id be good to run all 4 (or 3 even though i dont like odd number subs)off this amp and any suggestions on amp settings or ANY OTHER advice or opinions would be greatly appreciated . thank you in advance p.s. i am by no means a audio expert , i hook up my own stuff and friends who cant afford to go to the shop .
XX7R Posted March 12, 2011 Report Posted March 12, 2011 Just make sure you match up the ohm loads right! And yes you can overpower subs as long as you dont have the gain too high. LOL what the F is a "Dragon spider design?" Lmfao at the marketing in some of these mainstream companies.. 1990 Nissan 300zx Twin Turbo - Summer Ride(No system yet, lookin to get it up to 450-500 horse first!)2006 Chevy Malibu - Daily DriverDC Level 5 15", 2 APSM-1500's, 3.88 cu. ft. tuned to 32hz1992 Honda Prelude - SOLD2 18" TC 3hp Woofers on a Crescendo BC3500.1d, 12.7 cu. ft. tuned to 35hz
bigjdawg Posted March 12, 2011 Author Report Posted March 12, 2011 thanx for the reply xx7R . i dont have the slightest clue what a draggon spider design is lol i think its the way they weive the spider mesh under the cone (cant think of the proper name 4 it). i been lookin around for the best way to tune my amp with not much success . these kenwoods have been really good to me , turnin heads everywhere , but the 2 are getting lonely so i got two more on the way to give them some company lol , all i have is the one 1800w amp for now till i get more paper stacked up so i was wandering if it'd be ok to run all 4 off one 1800w amp till i get the second one , and what would be the best way to wire them so i dont fry anything , all 4 subs are 4ohm svc and the amp is stable down to 1ohm , ive been told i could put three 12's wired to 1.33 ohms on this particular amp but i dont like odd number subs . any advice is appreciated and applied if applicable to my situation . thanx
