DC Sound Lab
Level 4 Cut-through
Guest Wood
did a few more things, mounted my gain nob where the factory SR5 clock goes. wired in a switch to the remote, welded a couple more braces in, one on the bottom of the inner frame, then another outside the box in the back. then started going WILD with some guerrilla tape to try to seal off the back wall. i made a lot of holes and stuff from mounting old boxes in there and what not. also hope it helps with the resonance of the back wall.
  • 2 months later...
it doesnt look like you used filler at all in taht actually. the only thing i can see is you can see the line where your panel meets the factory panel.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
yeah i did, used bondo, the combat spot putty on top of that. just not very much. the bondo it the light green and putty is brown. i needed to feather the edges a lot more but i only spent like 2 hours on it...
for two hours thats pretty damn good. one of the best things ive found for stuff like this is the flex filler from urethan supply.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
thanks man, and yeah i didnt spend any money on anything, im strapped, just had this stuff left over from painting my truck and the fiberglass from building my box...
nice flex, can't wait for my blow through
thanks, i have some better videos somewhere floating around, ill post em in here.
  • Who's Online   1 Member, 0 Anonymous, 1701 Guests (See full list)
