I personally used some butt connectors alot of people throw a peice of shrink tubing on there before soldering the connections together then cover it up and heat the shrink tubing over it.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
I was wondering what connecters/adapters can I use to hook up my volt meter?
Thanks
is it the stinger volt meter?
i use male/female connectors so i can unplug it if i need to
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Personally where do you think is the best place to hook it up to?
Thanks
No it's just a voltmeter I bought off of eBay. But the wire is 26 gauge I need something that will fit that.
Thanks
id hook it directly to your amp so you can monitor the voltage at the amp
you can get size specific connectors but the smallest ive seen at a advanced or auto parts store is 16 gauge but that will work just fine
Thanks
Also another question I have four different wires I have blue, red, black, and green why?
Thanks
blue would be remote
red would be constant 12v
black is ground
as for green, i have no clue
Thanks
black is ground
How do I hook up the meter to the amp?
Thanks
black is ground
red wire in the power input of the amp
black wire in the ground input of the amp
blue wire in the remote input of the amp
  • Who's Online   0 Members, 0 Anonymous, 597 Guests (See full list)
