americanbass7707 Posted March 19, 2011 Report Posted March 19, 2011 ok, well i wired up my two twelve inch american bass subs, with a 840 watt volenhag amp in my 95 neon. i used a four gauge power wire, 8 gauge ground. it hits a little. but i have to put the balance to either right or left to make it work. can anyone tell me how i can fix that? its like only one is hitting, and the other just follows if someone could please help that would be awesome. thank you.
cubs_fan0718 Posted March 19, 2011 Report Posted March 19, 2011 I will tell you always use the same size ground and power wires when hooking up a amp. 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017
RickyFriery97 Posted March 19, 2011 Report Posted March 19, 2011 I will tell you always use the same size ground and power wires when hooking up a amp. X2 If the amp accepts 4 gauge power/ground use 4 gauge for both 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
