eder69 Posted March 20, 2011 Report Share Posted March 20, 2011 A friend of my mine is putting a 12'' RF P1 single 8 ohm sub in his car. He needs to know what amp would work good for it. rms is 150 watts and 300 watts peak. Single 8 ohm. Any other info just ask. Thanks. Link to comment Share on other sites More sharing options...
dthomas Posted March 23, 2011 Report Share Posted March 23, 2011 I would think any amp that puts out around 300-400 watts @ 4ohm, since it should put out around 150-200 watts @ 8ohm. I would probably used a decent brand amplifier since the resistance is out of normal range for most car audio amps ( 1ohm - 4ohms ). I don't think it would cause any problems because of the higher resistance. Unfortunately running @ 8ohm will cut the power by roughly half of most amps. --David Link to comment Share on other sites More sharing options...
Babyjuice Posted March 23, 2011 Report Share Posted March 23, 2011 This is just my two cents but I've ran a kenwood sub that was 8 ohms off a kenwood kac 8104d and it sounded amazing for the low power and I believe that kenwood amp is the perfect power for it imo BABYJUICE Link to comment Share on other sites More sharing options...
