4th order help for sa-15's
creed9
Working on a 4th order design, I got 18.5 cubes to play with I also have 4 sa-15s but know that I can't fit 4 of them in the space I have but is there room for 3 of them? I was thinking 6 sealed and 13.5 ported tuned to 44hz. Does that sound right? What would you do?
go smaller on the sealed part around 1.25-1.75
and go with 15 cubes or whatever your left with
and having it tuned to 44 will be low low haha so should work out well
R.I.P!
(Nov-29-2009)
92 explorer
current build
If you have 18.5ft^3 to play with, then you don't have room for 6ft^3 sealed and 13.5ft^3 ported because you have to figure in all of your displacements as well. I'd double up the entire box also. Without knowing what dimensions you're working with it makes it hard to recommend a layout for you.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
  • Who's Online   0 Members, 0 Anonymous, 1412 Guests (See full list)
