Its the load, take your meter, and check ohms between both pos. terminals
I bet it is a direct connection.
and the gain being only 1/4 of the way up means nothing but you have a hot signal coming into it.
It is a input sensitivity adjustment only
Sounds like its ia20.1 time for you.
Posted (edited)
ya i know what you mean about the gain. i just meant that if it was wired to low and the gain and bass boost were way up if it would heat up trying to put out the extra power or from clipping or something. i cant check anything till tomorrow when i get the truck back....what do you mena by direct connection and are you saying that theres something wrong with the amp?
Edited by jcm1689
